Finished my back plate today(120mm wide 300mm high 12mm thick), had to mill the surface that is in contact with the back of the column. Not the best finish but at least its flatter than it was to start with.
Snapped a drill bit drilling one of the holes! which has cost me a few end mills trying to get the bugger out!
Didnt make a brace bar like some of you did, as you can see i drilled my first set of holes in the wrong place! I used some M8 threaded studding, put a washer and nut in between the back plate and base. Tightened this nut up against the base, then tightened the nuts that pull the back plate back in in equal increments.
The holes in the steel plate that the M8 studs go through, i drilled 1mm larger so i've got so play for adjustment when tramming.
Thanks for the ideas guys, just need to tram it and maybe shim it for the y axis.
edit:
Turned the nuts around inbetween the backplate and base. nip up the outside ones equally and then tighten the inside nuts up nice and tight, then tighten the outside ones up again.
should i use the bottom nuts to adjust the Y tram? Or should i just shim the spindle housing if needs be?
edit:
