Reduce Vibration on tube Columns on mills, drill press & grinders, With torque arm add to mill
SmithDoor
Staff member
Global Moderator
Clovis Ca
Drawing for Improve Rigidity Reduce Vibration on Columns on mills drill press & grinders
Photo is torque arm add to mill stoping head from rotating (see left side on photo)
View attachment -2-improverigidityreducevibration-on-columns.pdf
Add photos
D
Well, this is certainly new to me... and clever in its simplicity.
So that heavy piece of hex bar is parallel to the column in the front plane and serves as a reference surface to line the new torque arm coming off the head up against? Is that correct? I gotta do that! And filling the column with concrete made a difference, too?
Thank you Dave!
Lloyd
