- Aug 25, 2007
- 3,890
- 715
blackfoxsteam said:Chuck
I am interested in your comment about difficulties with two cylinders operating out of phase including balancing the air supply. I am attempting a two clyinder beam engine (my second project, my first departure from plans) and I intend to have them 180 deg. out of phase.
Hi Dave, 180 degrees phase difference only presents balancing problems when the compressed air is being admitted to the two cylinders with different elapsed time between them. I assume your engine will have two power pulses per revolution, alternately 180 degrees apart, so the spacing between power pulses is equal.
I had difficulty balancing the air on my engine because I'm running the engine in 4 stroke mode where there were alternately 2 power pulses for one revolution then no power pulses for the second revolution. That's what causes the syncopated or loping sound. That meant there was always more time for pressure to build up in the line for the first power pulse than the second.
Again, there's never a problem balancing on any multi-cylinder engine as long as the power pulses are evenly spaced apart.
(For some reason this seemed really difficult to explain :-\)
Chuck
