Art K
- Jul 4, 2012
- 218
- 39
Ok, I did get the cam blank done but I will go into that more later. I don't want to go back between the two forums to figure what I have and haven't covered. So to keep in order and not confuse myself, what I did next was the muffler. I used the same program on the mill to machine brackets to silver solder on the end to bolt onto the manifold. After trying to use my propane torch I quickly found it didn't throw enough heat.
This is the first attempt. I later pulled out the oxy-acetylene torch and this was the result.
I soldered the dead end of each tube in, then the outer tube to one end. It all worked much easier when I changed the tip from #1 to 0 much better control. I then used some stock as a mandrel and bent the solder to fit around the inside of the tube and one to go around the small tube. That worked really well. Then I went on to solder the mounting bracket on to the end. Here is the whole works after being soldered together.
Next up was turning the end caps to the same diameter as the tubing. Filing the radius on the corners and some sanding to clean things up.
Mind you it wasn't quite as easy as it seems here, I waved the torch past the baffle tube and melted it in half, had to make a new one, that seemed to be a theme. Tried to do even holes rather than offset 1/2 the distance, that resulted in a new one. To get the two pieces that are just under 5 inches I used the whole 12 inches I got from the hardware store. Oh, and that solder joint at the top of the last photo, that's my favorite solder joint. But that was my third and last mounting bracket. More to come.
Art
Art
