- Apr 24, 2009
- 230
- 82
K
As to your question about speed, my experience is down to a #80 drill ie about .3 mm. For any hole in the range of #70 or less I use about 100rpm or less watching the hole with loupe. I take real light cuts and you can see the bit cutting. The reason for the slow speed is I cannot control the feed rate for running a drill at super high speed as charts call for, I just work harden the material and polish the flutes. I need to be cutting - at least for me otherwise I get a mess. The slow speed gets me cutting and produces a hole.
The setup must have zero run out at those sizes, any deflection will certainly snap off the bit.
The other issue is drill bit quality. I use PTD or Dormer in that size. If you look at suppliers less expensive under a microscope you will instantly see why to spend some extra money on drill bits. To start the holes that small I use 5/0 center drill but just nick it with the tip. I have used the ball method and spotting drill, both work but it is what you get accustom to.
I have never tried something as small as .2mm ie about .007" I think. I have seen a .001 hole that was drilled with a real special tool, I think it was a spade bit custom made.
