cessna
- Feb 28, 2010
- 183
- 4
:wall:Hi I posted the other day and got lots of help but still cannot produce a cam lobe. I have attached a clip from plans. Here is what I am doing with poor results. First I center the rotary table, then center the cam blank on the table. I then move the x axis left 5.66mm then move the y axis towards the front 2mm. I am not clear on setting the radius of the cutter, it calls for a radius of 11mm. If I set it 11mm from the new center, it will pass thru the center of the blank. The blank is 12.7mm in diameter (1/2").
I am probable going to feel pretty stupid when I find out what I am missing.
Thanks for any lite you shed on my problem.
Terry
Terry
