I not been able to orgainse myself to get much shop time this last couple of weeks and when I did snatch a few moments I didn't have the camera to hand. I also felt that the link cutting was not really of much interest to look at, well that's my excuse and I'm sticking to it, sorry or the jump in proceedings.
Anyway I have been working away on the linkage to connect the valve gear to the flywheel. My plan was to use the same bar stock as I did for the conrod; to make it fit and work in the square and then and then once I was happy with the operation do the turning operations. We'll come back to that at the end of the thread.
Here are a couple of pics of the rods in place.
I made a small brass bush to hold the pivot and the bell crank is cut out of same brass angle as I used to make my EZ engine rods.
On the small rod I had a real problem getting any of my lathe tooling anywhere near to it without fouling on the chuck so I used my parting tool. On the long rod I had my usual problems trying to machine the unsupported end with so much hanging out of the chuck. I did it in sections and used LH & Rh tools but the finish is still not as I would like. I'm going to experiment with some HSS to see if I can make a finishing tool to get a better finish than with my insert tools.
Due the amount of up and down movement on the long rod as it rotated around the crank pin I had to put a knuckle joint into the fixed end. As the only small milling cutter I have is a bit big to make the links this time I used a slitting saw and made three adjacent cuts for each slot. I'd not tried using one of these before but it seemed to do the job OK.
Well we are now at a point where everything moves freely when the flywheel is rotated so it is time to give it some air and see what gives. This video is the longest it has been run. I'm using a vice to hold the air duster attachment and this gives me a nice regulator too. Thm:
[youtube=425,350]<object width="425" height="344"><param name="movie" value="
http://www.youtube.com/v/KMeW3PWGXuI&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
http://www.youtube.com/v/KMeW3PWGXuI&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
Hope you enjoyed that. I'm really please I can get a nice slow run, I have increased the stroke a little and added some more weight in this flywheel compared to my EZ engine.
By cutting the slots in the rod prior to doing the turning operation it did ensure I had rods that would fit OK but I gave myself a pain trying to machine the rounds. When I do the job again (next engine) I will do the turning first. At one point doing the small rod it jumped out of the chuck, hence the scratch mark on it
So just the clean up / bling stage to do and she is done.
Nick
