Thanks for the kind words. It is at best a hack job, but it works. I used tapered bearings (trailer axle bearings) so I could elminate the play on the turret. It worked out very well, actually. For some finishing touches, I am going to put a scale on the slide to know what diameter (roughly) is being cut, and am also looking at mounting a tool bit on the opposite side of the insert to enable a range of shapes, rake angles, and the like for different applications.
For capacity, it should be able to cut about a 4" diameter ball. It will definately open up that far, but as far as how rigid the set-up will be once out there remains to be seen. I don't foresee ever needing to turn a ball anywhere near that large, but who knows! I never would have thought that I would have had to drill #80 holes, either!
W/E
