- Jun 24, 2010
- 2,425
- 959
Im having to make some design decisions around carburetor placement & intake tubes & how those elements are going to communicate with one another (
. and rapidly realizing Im flying by the seat of my pants at best).
Most of the model radials I looked at have a similar theme: spot the carb near the crank centerline & induction tubes going to the heads in a nice flow path, tarantula style. Makes sense to me. So why did the FS engine lay the carb very low relative to the crankcase? One would think this would create imbalances such as short U-turn path to the lower cylinders vs. the extra long path to the upper cylinders, especially #1. The path lengths from venturi to the intake valves are hugely different.
Was the carb spotted more-so for better intake air position relative to the airstream & suction/timing took care of itself? Or maybe some sort of lean/rich self compensation? (That would infer hotter cylinder on bottom, is that right?) One hears the term 'down draft' (carbs), why would that be important or advantageous in this case?
