Hi,
Newbie SteveO
Does anybody know if a CXA size toolblock will fit a BXA body. I need to use a 3/4" shank toolholder, but maximum a BXA block will hold is 5/8". I guess I could machine the slot to 3/4" on an existing 5/8", but would reduce the strength. If the 'dovetail' part is the same width for a CXA as a BXA I do not have height issues.
I believe the bodies are termed 200 (BXA) and 300 (CXA).
I can get a CXA from CDCO for $16 so not worth the time to make one and if I did I could not surface harden. I have considered machining down a 3/4" shank to 5/8" high as a possibility
Any and all help really appreciated.
SteveO
Newbie SteveO
SteveO
