vederstein
Must do dumb things....
- Feb 26, 2011
- 931
- 776
I don't like to criticize, but PM research are at fault:
Steamchick, with respect, that's a bit unfair. PM Research are not really "at fault". They are just providing a period-correct simple stationary steam engine model. I don't recall seeing such full size engines with a counterbalanced flywheel although there may well be some. Most basic traction engines and portables, for example, have plain spoked flywheels and even bent-from-round-bar crankshafts with no obvious attempt made to balance anything. Hence they gently rock back and forth when at work. Unfortunately, the model in the video is running way over scale speed which accentuates the imbalance. At 1/2-1/3 the rpm this would not be an issue...Vederstein, I don't like to criticize, but PM research are at fault: The flywheel needs a counterbalance weight to minimise the imbalance of the piston, rod, crosshead, con-rod and big-end masses. I simply hate manufacturers that sell kits that have not been properly engineered with a counterbalance cast-in to the flywheel.
negative criticism is not appropriate and detracts from the thread.
LOL, you are so right. ONe time I was critiquing someones story. I warned the fellow that often a critique NOT meant to be harsh, might appear to be ripping one's innards out, but is indeed NOT all that harsh. So this fellow had a GREAT sci-fi idea and wasn't all that bad of a story line. HOwever, he had certain annoying methods, particularly, every time one character would speak to the other character, he would ALWAYS say, " Bill . ...", then "Fred . ....", "BIll ....." "Fred..." Well people simply don't talk like that in real life. If there are a large number of people around, one might say the other fellow's name once in a while, but come on, do you know who you are talkinhg to if there are only two people involved? So I pointed this out and he thot I was being harsh. OH vey. He wouldn't talk to me after that. I thot it was horrifying because I wanted the fellow to succeed--and he DID have a pretty good story. He also had a major error but with one rewrite could fix that--not too difficult.In my world, negative criticisms are ok depending on the presentation.
Sometimes a criticism isn't meant to be derision. Other times they are.
I know that Steamchick didn't mean and harm based on earlier correspondence and the content.
Other's (particularly comments on Youtube) are meant to be hurtful.
Also, If I'm going to put my work out there, I have to be ready for the Hellscape that is the Internet....
Thanks,
RJC
