I am new to model engines and have a desire to ultimately build a v12 and a radial. Now I know that I won't jump right in to that level as my skills are not ready for that at this point. I intend to start with a wobbler.
Anyway this gets me to my question. What do members here think the next step builds should be in progressing from the wobbler to the ultimate goal builds?
If I posted this in the wrong place please let me know.
Thanks,
Here's the progression I would suggest:
1) Wobbler, as you've already said. This will teach you basic machining.
2) "fixed cylinder" steam engine from bar/round stock (no castings). more parts, closer tolerances, more "difficult" parts (like the cylinder) will all help improve your machining work. Suggest something like Elmer's Engines #33, or one of Rudy Kouhoupt's single cylinder engines (found in village press's "shop wisdom of..." series). The 2nd engine I ever built was Rudy's "Horizontal Mill engine" (seen here:
http://www.homemodelenginemachinist.com/engines/horizontal-mill-engine-113.html) and it taught me quite a bit.
3) Single Cylinder gas engine from bar/round stock. Once again, more improvement in machining skills, plus you'll learn about making piston rings and seating valves to get good compression, making a camshaft, and also ignition systems. Others have suggested engines that fit this category already
4) Multi-cylinder gas engine from castings. Multi-cylinder engines have more challenges than a single cylinder, like a more complex camshaft and crankshaft. Suggest either Westbury's "Seal" (a classic 4 cylinder engine that's been around for over 60 years!) or one of Bob Shores' engines (I think his "Hercules" is a two cylinder...)
By then you might be ready to tackle your "dream project". Just remember, learning how to use your tools takes time. Don't be afraid to "repeat" any of these steps. Don't be afraid to throw away a part, if you mess up don't try to "save" it or you'll just frustrate yourself. And don't be afraid to ask more questions.
Good luck!
