Have not see a self centering 4 jaw. I like the independent jaws to do off-set work. You do have to slow the chuck down. The imbalance can make the lathe jump around.
Have you ever seen a scroll (self centering) 6-jaw chuck?
I don't have it yet but it's on my wish list. HUGE LIST! :roll:
The 6 jaw is for chucking up thin wall parts without distorting them.
That 4" one would be perfect for my 9 X 19 Grizzly lathe.
Kenny it will run in which ever direction you spin the flywheel to start it.
Just start out with low pressure. It will run without even registering a
pressure on a regulator and at 5 PSI its buzzing!
I don't have any idea about the pressure. I did drill a smaller orfice in the inlet fitting to lower the air pressure. I forget what gas law covers dropping the pressure that way. Have an quick release on it and have plugged it directly into a 175 PSI air compressor and it drops the pressure just fine. I have to get a "T" fitting so I can tie in a carb gage to find out the pressure. That may take me a couple of days before I have the answer.
Thank you guys for the encuragement to make the Tiny. I love the way it sounds.
Yep, I have a couple of regulators. I have over 2 hours running on it now. It is so much fun to play with. I changed the bore and stroke from the print when I made it. It has a .2188 bore and a .250 stroke so that makes it 0.00939992796287948 cubic inch.
Don't know the HP, but I can say if you hold it by the base to show it off
running at high speed and that crank clips your thumb nail it will make
you say things that you normally wouldn't. :lol:
Done THAT!
I work part time in a camshaft shop and have been thinking about seeing if the head flow bench will pick up the air flow it is pumping. I know the little thing turn will not turn the dyno but I want to see if the software will say the HP it's putting out by logging in the specs.
I use Marvel Mystery Oil on the crank pins, shafts and eccentrics.
I've never used a lube in the cylinders of any of my own models, but
none of them have ever run for an extended period of time either.
I've heard some say that powdered graphite is a better cylinder lube than
an oil. I can't tell you if that is true, because I've never tried it.
Maybe someone else here has?
