AlanS
Active Member
I’m building a gear pump to circulate coolant on my Seal Major engine model. I wasn’t happy with the centrifugal pump I originally made. I found several formulae on line to calculate the flow rate given the size of the gears and the speed of rotation. Has anyone built a gear pump and measured the flow at a certain speed ? I assume if you built the pump you know the DP size, number of teeth and the thickness of the gears. The calculated flow per rev vary widely with the different formulae.
The picture shows me using the mill as a depthing tool. I didn’t have the correct cutter for 10 teeth so the centre distance has to be measured with no backlash allowance.
