The final step in the liner construction was to bring all the bores to a common diameter and then lap the i.d.'s for cast iron piston rings. Since neither the pistons nor the rings have yet been machined, the actual diameter isn't yet important. What is important is that the i.d.'s end up identical so a single diameter piston ring can be machined for use in all the cylinders. The resolution of my dial bore gage is about a tenth or so, and I was able to identically lap all the cylinder bores in my last two engines to within its resolution. So, I set the same goal for the Merlin's liners.
All twelve liners plus the three spares that were initially launched managed to survive their machining and avoid being scrapped. Initial measurements indicated all the bored i.d.'s were within a thousandth of one another, and so I was looking forward to a brief lapping session. However, the chatter marks with which I had struggled on some of the liners were deeper than I had hoped and weren't picked up by the anvils on my internal micrometer. After some localized clean-up on a couple of the worst looking parts, my dial bore gage showed the actual diameter spread was closer to .0025". This was really disappointing because the grooves on these parts ended up setting the final diameter of the entire group of liners, and what I had hoped to be just a single messy afternoon of lapping turned into days of grinding.
Each liner was engraved with a unique number so its progress could be tracked throughout the honing/lapping process. A set of worksheets was set up on which the measured i.d.'s of each liner were recorded at three different depths as the lapping progressed. With up to .0025" to be removed from many of the liners, I would normally have re-bored the whole lot, but I hadn't learned anymore about getting chatter-free bores on Stressproof than I knew when I bored the liners the first time. I zero'd the dial bore gage to the center of the spread so I could focus on deviations instead of trying to keep track of absolute numbers.
I used commercial Acro barrel laps designed for through-holes and Clover silicon carbide grease in three different grits: 280, 600, and 1000. A separate lap was used for each grit. The laps were mounted on an arbor and spun in a battery-powered drill while the liners were simply held in my gloved hand. This method of supporting the liners would have required greater care had I been working with the stock .030" thin-wall liners since a tight grip, especially needed for the coarse compound, would have tended to distort their bores. With the drill running at 300-400 rpm, the liner was slowly oscillated along the length of the lap with about half the lap being exposed at each end. The liners were always slipped onto the laps through their bottom end to avoid accidental damage to the sharp sealing edges at the tops of the liners. These sealing edges are an important reason to avoid using brush or bottle hones on the Merlin's liners.
Since the starting bore was a non-standard 1.198", I modified the stock Acro 1-1/4" brass barrels by turning them down to 1.195". With so much liner metal to be removed, I started with 280 grit grease. This coarse compound was extremely abrasive to the laps, and the grinding process removed about the same amount of material from the laps as it did from the liners. The expander bolts on the ends of the laps had to be continually adjusted as the lap wore, and it was necessary to take small steps in between many measurements in order to avoid overshooting targets. I probably made three to four measurements during the removal of each half thousandth. By the time all the liners had been ground to a common diameter, two 280 grit laps had been fully expanded. Measurements showed their starting diameters had been reduced from 1.195" to 1.180" by the grinding, and this volume of metal was nearly identical to the volume of metal that had been removed from the liners. Even though I was using barrel laps, I wouldn't consider this first step to have been a lapping operation. It was more of a controlled grinding operation used to bring all the liners to a common diameter.
The 280 grit grease produced a surprisingly smooth and beautifully frosted finish that was free of visible machining marks or scratches. The real lapping, though, began with the 600 grit paste after the liners were all at the same diameter. During this operation only a tenth was removed from each of the nearly finished bores, and maybe a thousandth from the single lap. Each tenth took longer to remove than when working with the 280 grit paste, and so it wasn't difficult to get all the liners to precisely the same diameter with fewer measurement checks.
I've learned during lapping that there is some technique involved with using a (my) dial bore gage. My only experience with these gages is with my own imported model, and so I don't know if a more expensive gage behaves in the same way. But mine seems to have one or two tenths backlash. When I rock the anvil back and forth inside a bore to take a measurement, I get a slightly different result depending on the direction that I rock the gage. I've learned to make it a point to approach all measurements from the same direction when making comparisons.
I finished the liners with 1000 grit compound which didn't remove any measurable amount of metal but did seem to improve the surface finishes a little. I'm not sure if the 1000 grit pass is needed or even desirable for cast iron rings, but since I used it on the cylinders in my last radial I also included it in the Merlin's liners.
My process for getting all the liners to a common diameter was not to grind on each one continuously until it was at that final diameter. Instead, I worked in small steps across the whole group of liners to finesse them all, as a group, across the finish line. This approach took more time and involved many small steps and measurements, but it helped to avoid accidents, and it better handled surprises such as undiscovered grooves or scratches. It was also easier to spread the work out over several less tiring sessions over several days when not grinding incessantly for long periods of time on the same part. Changes in the lap (and the lapper) were slowly spread out over a number of bores for a more consistent final result.
The 280 grit compound typically required about 5 minutes of actual lapping time to remove a couple tenths from a single liner, but when the times for cleaning and measurement were added, the total time was closer to ten minutes. It was important to thoroughly clean and dry the liner before each measurement to not only get consistent measurements but to also avoid damaging the gage's anvils. I used kerosene for removing the lapping grease, and it left me smelling so bad that neither the wife nor dog would come around me for days.
After the 280 grit grinding was completed, I let the parts sit for a day so I could rest up for the final 600 grit lapping step. For consistency, I used the 600 grit lapping operation to remove the last tenth from all the parts in one session. The final result was that 14 of the 15 liners finished out to better than a tenth with beautiful smooth finishes. There were no measurable circularity errors after (or even before) the lapping. The 15th liner had the deepest chatter marks, but It would have likely cleaned up with another two or three tenths pass. Since the other fourteen liners were already at the finish line, I decided that having a third spare wasn't worth the effort or risk to the other liners. - Terry
