I took some time off for travel to visit my youngest son and to attend my newest grandson's first birthday party. With me I took a single Merlin drawing so I'd have something to keep my mind occupied during our quiet time. This drawing contained the design of a three-piece cover for enclosing the timing chain and sprockets. Four aluminum tubes interconnect two upper covers located at the rear of each head with a third cover enclosing the idler sprockets at the top of the wheel case. I spent many hours before and during our trip trying to visualize these upper covers from the flat views in the drawing. These two covers are the most complicated parts in the assembly, and their dimensions are critical. But, most of their design is contained in a sectioned view of a drawing detail taken from a top view of an assembly drawing of an installed cover. All the information was there, but with no photo or isometric view to help me get started, they just didn't want to come into focus for me regardless of how long I stared at them.
After returning from our trip, I began modeling them in my CAD software. After a couple days of trial and error but no 'a-ah' moments, parts slowly took shape that reasonably matched the drawing. To make things a little more interesting the drawing contained the design for only one cover, and it had to be mirrored to get the second one. Some of the dimensions had to be changed to fit my particular castings, and I also made some changes to the mounting screw locations since there appeared to be issues with the ones in the drawing. After compiling my own 3-D assembly it was obvious what the drawing was trying to tell me, and I'm embarrassed to admit how much I had struggled with it. In any event, I've included several photos of the final parts so the next builder will have a better starting point.
This timing cover was not part of the original Quarter Scale design. From what I can tell from translating Gunnar's diary, it came into existence after he complained to the original designers that the engine needed a cover and that he intended to design one. The designers apparently agreed, designed one of their own, and sent him the drawing that I've been working from. This drawing was included as an addendum to the rest of the Quarter Scale documentation, and it's dated without revisions to the time Gunnar was working on this portion of his engine. Notes accompanying the drawing warn that the design is intended only as a suggestion, and modifications and individual fitting may be required. I did find it necessary to make a few changes; but, over all, the design seems pretty well thought out, and it's nicely integrated into the engine's overall design.
The three machined covers will be connected by four metal tubes in a close-fitting rigid assembly that must clear the chain. I focused only on the two upper covers at this time and will probably make the third one later along with the rest of the wheel case components.
The top covers were every bit as complicated to make as their drawings were for me to understand. Eight different set-ups were required to machine all the features on each cover. Construction began by contouring their outer peripheries from chunks of one inch aluminum. A clearance notch was then milled along one side of each cover in order to clear a flange on its head. It's important for the depths and angles of the holes that are drilled and counterbored for the interconnecting tubes to be spot-on so the three covers can properly mate up without interfering with the chain. I used a sine plate to set the head of my mill for these operations. Although I got the angles correct, I managed to scrap several hours of work when I reversed the two degree angled holes on both parts. These particular holes were a constant source of confusion for me since, to me, they always seemed to be going in the wrong direction.
After re-drilling the holes in a pair of new parts I milled the shallow rectangular pocket in the top of each part which allowed me to compare the drilled hole intersections with those in my CAD drawing. When the intersections didn't match I realized the first two parts were actually correct after all. I exchanged my two new workpieces for the pair I had thrown into my scrap pile and continued on, hoping the brain cobwebs would soon clear.
The next step was to machine the clearance pockets for the cam drive sprockets. These pockets are contoured to fit very closely to the diameter of the sprocket with its chain. My piece of NOS chain had arrived while we were on our trip, and so I was able to use it later to check the clearances. I set the first cover up on my lathe faceplate in order to bore the pockets, but while I was trying to make up a one-off boring bar I decided to CNC the pockets using an ordinary end mill on my Tormach. The pockets came out looking great, but the end mill's diameter reduced the clearance to the chain a little more.
I filleted the rear outside corners of the covers. This wasn't a part of the original design, but I thought it was a nice touch to what had turned out to be a couple of really miserable parts. The final step was to drill and tap the five mounting holes in each cover and head. The drawings called out 1-72's but warned that washers might be required due to break-outs created by the limited drilling space. I dropped down to 0-80 button-head socket screws to avoid this, but I had to carefully match drill each pair of holes. I'm really, really glad these two covers are finally finished. - Terry
