JimDobson
- Sep 11, 2013
- 273
- 255
I signed on to your Youtube channel this morning and have already viewed 3 of your videos.
Great job.
Jim d
Thanks Jim, much appreciated.
Great job.
Jim d
Putting some grip (stippling) on an aluminium drive pulley.
I've always wanted to work out a way to put some extra grip on a home made drive pulley to prevent or cut down on belt slippage. It would be nice to have the tooling that Wilesco use on their grooved pulleys. I had a Dremel saw accessory that the outer plastic shell broke and I thought what can I do with the saw blade. Rudimentary, but it worked well. I should be able to work out now a way to mount it so it doesn't need to be held, though its not as dangerous as that looks and being hand held allowed me to skew the saw blade at the various angles needed easily.
I would drop the pulley in some battery acid and run a current through it for half hour. Anodise it if you don’t seal it it will have a rough Matt finish
Oh dear here we go again.
I was specifically referring to your contributions to the topic. Specifically, your post numbers 11, 14, 17, 18 before finally mentioning safety in post number 22. I was making the observation that for someone so vehemently opposed to the 'dangerous' technique used, it took a lot of posts before you mentioned it.Dear Cogsy you really should read comments more carefully. You make a point about the late introduction of posts regarding safety, if you had read the postings you might have noticed that the first safety message was in the third or fourth posting by Norman (Goldstar31) the following day after Jim's original one (and allowing for the time difference between Australia and th eUK it was a pretty prompt reply - well done Norman) and the discussion of the merits of stippling only occupied a couple of short posts.
Again, I will reference that not all videos, or any content, is published with beginners in mind and nor should it be. Whether it be machining, electronics, firearm use, motor vehicle operation (especially motorcycles) or a multitude of other topics, there are countless videos, pictures and even tutorials which assume knowledge of (at the very least) basic techniques and safety practices. Perhaps a simple 'don't try this if you're not experienced' could have been added, but the vast majority of content producers do not include such a disclaimer, nor do they mention every specific hazard (or often any at all) in their videos. Again I'll refer to the excellent videos of Joe Pie or Myfordboy for examples (filing left handed immediately jumps to mind for Joe and I've never noticed a warning from Myfordboy about the dangers of CO poisoning from a propane furnace in an enclosed area).You accuse me of attacking Jim, please read my first paragraph again where I say what Jim does in his own workshop is up to him, but not to put it on a public platform where inexperienced beginners may take it as advice without a simple spoken warning.
Perhaps strangely, the international standards I linked to in my previous post does not specify a length of cloth that can safely be hand-held under power, just that that emery cloth must never be hand held when under power on a lathe. There is even the suggestion that alternative methods should be considered, so that if possible, emery cloth is not used on the lathe even without being hand-held.As for emery cloth on the lathe I use lengths approx 18 inches long from a reel 1 inch wide made specially for the job. I hold the ends lightly at a distance of 6 to 8 inches from the work so that if it catches (unlikely but possible0 it is pulled from my fingers.
A couple of points here - you described the technique in one of your posts in this very thread without discussing the safety aspect (yet you say rank amateurs may be reading this thread). You also suggest the technique is safe because safety conscious craftsmen taught it to you, which somehow means documented international safety standards can be disregarded.if I were to demostrate th process I would certainly discuss the safety aspects while working, it doesn't cost. My technique was taught to me by very safety concious craftsmen, not amateurs working at home. The only other abrasive material I might use is one of those emery coated sponge blocks whic h can safely be pressed against the work. I also find it rather ironic if not amusing that I am being lectured on H&S by someone who spends so much time denying it.
I'll have to trust you on this. My only experience with this type of tool is with old, well made examples. But my intuition suggests that modern, cheap eBay junk would be incredibly flimsy, which is what I based my comment on (and yes, you did suggest picking up a cheap eBay example).As for the leather prickers they are not at all flimsy, especially when compared with q dreme saw,the wheels are around 3 - 4 mm...
I've bolded a couple of bits of your paragraph just for clarity, and I'll cut-and-paste the beginning of the post in question (post #111):You further accuse me of not getting names correct. Again read my first paragraph and note that I called him JIM. In the following paragaph I was addressing SteveM concerning his comments about safety comments spoiling a cricket match which I found ironic as teh batter and close fielders are a standing advert for H&S with all their protective equipment. I am not responsible for your confusion but apologise if you didn't get my satire.
As I have said, I have great respect for many of the content providers but they certainly do not always show best practices in every instance. I've already discussed a couple of examples and if I had more time (and inclination) I could dig up an early Joe Pie lathe video where he takes his hand off the chuck key while it's still in the chuck (notice he crops his videos so he can't make that same slip-up nowdays). Or go watch some of the Myfordboy casting videos where he pours molten metal over concrete flooring without any mention of potential steam explosions from spills.As for your ridiculous statement that not all postings or videos are not intended for beginners, who are you to know who watches and reads them, there's no special partition between experienced users and beginners on the internet that is why qualifying comments are necessary occasionally. Of course content generators are responsible for the possible outcomes of that content your declaration otherwise is gob smacking. The examples of providers you quote are all competent and scrupulous people demonstrating correct and safe procedures. As for the videos produced by much more professional YouTubers they diligently demonstrate safe procedures not bodged up methods and dodgy unsuitable tools. I have been watching videos by users such as Myfordboy who you mention for many years and remember his early casting videos and was once able to offer advice when he was having problems with cores.
I believe I've correctly read, and understood, the previous posts, and I would ask you to follow your own advice - before you accuse me again of mis-quoting you, please go back and verify what you actually wrote originally.To repeat, please read, view and understand the posts that are here I note that Norman (goldstar31 has added his thoughts on your post before I got to mine.
A Thoughtfor the dat?
What happens if someone follows the advice?
It's Remembrance Sunday and I'm one of the lucky ones. I can merely claim to to be deaf as a result of what was never recognised as a a war. Oh I got a little bit of money and waited for 70 years for my Government hearing aids to arrive.
When you go home
Tell them of us
For YOUR tomorrow
We gave our today.
To Mac and Tony and poor Fred.
RIP
I have a Mamod TE1 I bought in Norfolk Island over 30 years ago. Still in the original box. It has a much more basic piston, but is otherwise identical to yours. Is the gas burner original or is it an aftermarket product?
Gak! Did I read right? Norfolk Island? The island of horrific slave mutilations and degradation? Do you see ghosts over there? How do hyou travel to the island?I have a Mamod TE1 I bought in Norfolk Island over 30 years ago. Still in the original box. It has a much more basic piston, but is otherwise identical to yours. Is the gas burner original or is it an aftermarket product?
Norfolk Island?
It was the convict stuff that I meant, my understanding is that they were tortured, enslaved to the most horrible stuff, even worse than Devil's Island, left to murder and canibalize even. so I am wondering how many ghosts roam around trying to get even or eat someone.That's the one. You can fly there. It has a tiny runway that a 737 can just manage to land on. I was in the Air Force at the time and we had to stop there for fuel on our way home from New Zealand. I'm not aware of any slavery in its history, but it was a miserable place for the convicts who were kept there. It's tiny and there's not much to do there, but surprisingly it had a toy shop!
Here in South Africa it is simply illegal to operate machinery alone - I can't have a single person work overtime in my factory for instance - nor am I allowed to have one of my technicians conduct repairs at a clients empty premises. These rules contain no exemptions for small or home based workshops.
Seems fairly sensible but if strictly obeyed means I can't use my home workshop unless I have my wife standing by "supervising" me - please ! My workshop is my refuge from her.
Regards, Ken
