black85vette
- Jan 18, 2009
- 1,084
- 25
Timing is easy. Put the pivot on the flywheel at 12 oclock then put the pivot for the crank at 9 oclock. They are 90 degrees apart to start out. Tighten the set screw for the crank allowing some clearance for the bushing so it does not bind. The bushing can be moved left and right to line up the connecting rods which should be straight with the piston and valve. If you want a thicker flywheel just make the bushing shorter to keep the alignment correct.
