Steve
Active Member
Here is my new project , all scratch built except for the fly wheel and the pressure gauge........ I was inspired to build this project after looking at the York Steam Plant ....... The Bore is 15mm and the stroke is 45mm , The flywheel is 7" , The boiler is made from 3.5" x 1.6mm copper tube and stands 11.5" to the top of the chimney . I tested the boiler with compressed air to 120psi for 2 hours and all seem fine , i have made the safety valve to blow off at 50psi . the gas burner is a ceramic , that was a challenge to do as i couldn't fined any detailed info to make one , so it was trial and error ...... The Gas tank is made from 2" x 1.2mm copper tube and silver soldered , same for the sludge tank and the reservoir
Here are some photos and a video in steam.
