Progress on V12 Plans
Hi All
Making some progress on my V12, I cut everything down by 50%, Less than 7" long. Going to be fun to build. Bore .625, 6 PAK carbs each feeding two opposing cylinders, I have ordered a CDI for the distributor. I figure another two or three weeks to complete the design. I'm using Dale Detrich's concept carburators, modified slightly. (with his his permission)
Jack
:eek:
View attachment Assembly2x.5.pdf
View attachment Distributor_V12.pdf
Coming together into a respectable engine. Very inspiring.
Frank
Nice design, if I may add I would do three rings per piston. A oil ring, scraper ring, and compression ring. Without the third ring you run the risk of getting to much oil into the combustion chamber and smoking or worst yet fouling your rings.
Just my two cents,
John.
Very nice, I wish I had these computer skills.
