Thanks guys: It's coming down to the home stretch for sure.
Just a short update on two little jobs completed before starting on the fuel system.
A good buddy in Australia sent me a note saying that their boiler codes require a means to lock the pressure setting on a safety valve. It is possible over time for the safety to jiggle loose and come apart. The usual method to lock the safety is with a jam nut. Its the right thing to do and the fix is so simple; there is just no reason not to do it.
The fix requires a simple modification to the existing valve body and fabrication of a jam nut. Chuck the valve body in the chuck spigot and turn off 3/32. Thats it. With the jam nut heres our safety valve mod:
The safety is not set for pressure yet. It gets set later during a steam test of the boiler.
The second job is a new throttle body. The boiler nipple on the old throttle body is too short, making it difficult to install on the boiler. The drawing I made for the throttle body is correct. If you follow the drawing, the throttle body will install just fine.
In making the new throttle body, I used the fly-cutter method to machine the linkage tab. Make a threaded jig to hold the nipple.
Use the parting tool to shave down the sides of the linkage tab. It worked out sweet.
The new throttle body sits taller and is easier to get on the boiler.
Next week well start on the fuel system. The fuel tank is going inside the cab. The other day on the Internet I found a micro sized pressure regulator that might be worth an experiment. If Nina runs good, it may end up a test bed for do-dads like a pressure regulator. So for now I want to keep the fender position available.
