Presto-Lite torch rebuild
chucketn
Senior Citizen
Near Jonesborough, TN
I am in the process of rebuilding my Prest-O-Lite Acetylene(originally Union Carbide) torch. It’s 60 or so years old, inherited from myDad. The o-rings in the valves have all hardened and the 401 handle leaks gasaround the valve stem. I have ordered the proper o-rings from WeldingSupply.comas per the original instructions/parts list from Prest-O-Lite. I tried o-ringsfrom a kit from HF with no joy.
My question, should I use some type of lube on the newo-rings when I install them?
Chuck
Well as we all should know it's a fact you should never use oil or grease of any kind on oxygen equipment or any modern gas apparatus.
That being said the old prest-o-lite torches are not modern and don't have oxygen running through them. Acetylene gets along with most non-metal things OK so I have to go out on a limb here and say it won't hurt anything, but I'm not an expert. :) As to whether or not it is advisable and warranted, I really don't know. I do see where it would lengthen the workable life of the o-ring.
I have one of these same torches, but it still seems to work good for me. I hope you can take some pics of your rebuild and post them here. :)
The Prest-O-Lite torch is an acetelyne/Air torch. Is there a legitimate o-ring lube that can be used in this application?
Chuck
you are likely OK with a silicone grease but to SAFE check with presto lite or a welding supplier.
Krytox is rated for reactive gas so it would be safe .
On any equipment designed for dry seals I would NEVER risk using any product for that purpose... If your o-rings don't seal when dry, you really want to know why...
Septic has a good point . while krytox is non reactive these systems are designed for no oil. Follow manufacturers recommendations when in doubt.
I forgot to mention that I've been known to purchase a lot of used gas apparatus. I usually get my used stuff refurbished by the local welding shop. They do great work, it comes back looking brand new, and I've never spent more then 50 bucks on a piece for professional work.
I have received and installed the proper O-rings for my Prest-O-Lite Acet/Air Torch. I’m pleased to say it no longer leaks around the shut off or needle valves.
Next question, does anyone know how to adjust the shut offvalve? I have the origional Prest-O-Lite/Union Carbide instructions for the 401Torch Handle but they aren’t very clear on setiing thes valves after replacingthe o-rings. Even with the shut off valve turned all the way in, the pilotvalve will open enough to get a small flame (pilot), but the shut off has no effect.
The problem is that the shut off valve handle is a set screwsecured collar on the valve body. The valve has a stop that prevents rotatingthe valve more than 360° so adjustment is a process of removing the outerhandle, adjusting the valve and reinstalling the outer handle to test.
I did not post pictures but here is a link the instructions I have.
http://www.google.com/url?sa=t&rct=j&q=prest-o-lite%20401%20instructions&source=web&cd=1&sqi=2&ved=0CCoQFjAA&url=http%3A%2F%2Fwww.esab.ca%2Fliterature%2FArchive%2FManual%2FF-9000%2520-%2520F-9499%2FF-9324-J_PREST-O-LITE_401_TORCH_HANDLE.pdf&ei=k6DZUejGO4r48wT_7IG4CA&usg=AFQjCNFMvFPZ4XJQfkU5UgvvemBwaUGmRA&bvm=bv.48705608,d.eWU
Chuck
