Below a is schematic diagram for a Delavan siphon nozzle burner.
I use 10 psi compressed air pressure to pressurize the fuel tank (be sure your tank will hold pressure if you do this), with a 30 psi safety valve.
The 10 psi gives a consistent diesel fuel flow at all times regardless of fuel tank level or any other variable.
I use an automotive inline fuel filter in the fuel line just before the burner.
I use about 30 psi compressed air to the siphon nozzle (atomizing air; this is labeled "AIR IN" in the schematic diagram below).
Some folks use slightly less compressed air, but I have found you can have fuel puddling if you get much below 30 psi atomizing air.
I use a #30609-11 nozzle, and a #17147 adapter with the siphon nozzle burner.
The chart below lists the #30609-11 at a nominal 1 gal/hr fuel flow rate, but it actually operates over a wide range of fuel flows, depending on your compressed air pressure, and fuel tank pressure if you are using a pressurized fuel tank.
I have seen folks melt iron with diesel, kerosene, cooking oil, waste oil, etc., and they all seem to work well as long as they are clean and well filtered, and will flow to and through the nozzle without clogging.
Some hydraulic oils are reported to be toxic when burned, so use caution with what you are using for fuel.
Waste oil can be contaminated with sludge, water, antifreeze, heavy metals, etc., which is why I avoid using it.
Edit:
Note that the Delavan siphon nozzle is called a "Siphon Type SNA" by Delavan, not to be confused with a "Pressure Nozzle", or other types of nozzle styles.
Also note that the Delavan siphon nozzle and the Delavan pressure nozzle both screw into the Delavan #17147 adapter, however, siphon nozzle and pressure nozzles are piped up differently.
A siphon nozzle uses a siphoned oil input line, and a compressed air line.
A pressure nozzle uses a pressurized oil input line (at about 100 psi), and generally a return oil line to the fuel tank.
I am not aware of any spray angles offered on a siphon nozzle, but the pressure nozzles are offered in a range of spray angles, and can also be purchased with solid or hollow spray cones.
