I need one of those![]()
wooo three of us from toronto![]()
Jeff thanks for the great pics. 2 questions:
Who manufactured the saw?
Does the saw continue to reciprocate but stops its downward travel when the bosses on the frame touch the hub for the large sprocket?
Thanks
JohnMTO
I use a 1/4" cylindrical stone in my dremel to grind a hole where I need it in the blade. ( No punch )
I make a mark along the entire width with a marker and then grind using the edge to make a small divot. Turn the blade 90* and repeat. Turn 90*, repeat as many times as needed. Once you think you're over half way thru, turn the blade over, match the line and grind from that side. Just a few minutes makes a nice round hole.
Works great with my power hacksaw
click
Interesting . I do not really ever seeing one like that even in catalogs. I like it. for steel bar or drill rod it could be handy. One of the local HW stores has starrett HS blades fairly reasonably priced. how bad does it shake the bench ?
