- May 27, 2010
- 2,999
- 1,171
DRO was urgently required and must have latest today/tomorrow to mill the Inlet and Exhaust Cams for Nemett-Lynx Engine now very far behind completion. DRO from LMS would cost a bomb landed in Singapore. Same from ArcEuroTrade cost 54 British Pound and DHL not included.
1.Had tried using a Magnet Stand and Dial.Mill is too small.
2. Made a clamp to hold dial. Ruined the M.I.C. Dial in seconds with wild oscillations caused by the residue vibrations from mill. Dial eventually spun like a high speed clock. See foto 1.
3. Made ''Bush'' Clamp to hold M.I.C. Digital Vernier. See foto 2. Zero back home was initiated using my right hand until a brain wave came. Use elastic band.
4. With Digital Caliper at full length made reading difficult. Clamping on caliper need upgrade. Chopped 150mm Vernier to 60 mm Was kind of painful to chop a friendly caliper.
See foto 3. Tension Spring was in mind but drill a hole thru the hardened jaw was impossible.Reluctantly went back to ''Bush Engineering" with Rubber Band.:hDe:
Now looking at using same set-up for the Sakai Mini Lathe.
![IMG_1277.jpg IMG_1277.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/27/27349-IMG-1277.jpg)
![IMG_1282.jpg IMG_1282.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/27/27350-IMG-1282.jpg)
![IMG_1287.jpg IMG_1287.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/27/27351-IMG-1287.jpg)
