nz120
BaronHi Nz120, I'm curious as to why you are using a rotary table ?
I set up the rotary table to allow me to rotate to a 45 degree angle for the valve slide recess to be milled. I squared up the casting using a dial gauge along the flat of milled face of the valve guides on the casting and then rotated.
When I do the second kit I am thinking to mill square faces to the base of the frame casting so that I have true faces against which to make it simple to mount and remount - i.e. If I had done this then I could easily set at 45 degrees onto the bed of the mill.
Being self-taught, the "obvious" solution to any problem is
not always obvious to me haha
