vcutajar
- Nov 6, 2011
- 862
- 168
Good morning
I need again to tap your expertise.
I have just finished honing the cylinder liner for my Kiwi MK II and would like to ask some questions about piston rings. I have searched the internet and this forum but could not find exactly what I need.
The piston rings that came with the kit are slightly large. If I compress them they will not enter the liner. So I guess I have to file one side of the gap so that they will fit inside the liner. I understand that when the ring is in the liner there should be a gap (I think they call it end gap). How much should be the gap? I have found that the gap on the first ring should be 0.004" times the bore diameter and 0.005" times the bore diameter for the second ring. These are for full size engines. What gap would you use for a model engine with a bore diameter of 1"?
How do you insert the piston with the rings in the bore. For full size engines a ring compressor is used but I could not find any which handle a 1" piston.
Also am I correct when I say that the piston with rings and conrod should be inserted from the top of the cylinder?
Thanks in advance
Vince
Thanks in advance
Vince
