Piston Pin matterial
borna
Hello all,
I got this Chinese multi-cylinder engine, and during the assembly, I noticed that I am missing one piston pin. This is a picture of one set of piston, pin, and connecting rod. Since I decided not to wait for them to send me a piston pin, I’m planning to make my own. That said, the piston is aluminum, and the connecting rod is most likely brass or bronze. So, my question is: What material is best for making the piston pin? Can I use HSS? Should it be hardened or not? If HSS is not a good metal for it, please let me know what to use?
Thanks
    463.8 KB
You could use either a piece cut from a drill blank (HSS) or you could use drill rod or silver steel depending on what it is called in your area. Either water or oil hardening are ok and no need to harden the drill rod in this application.
Please let us know how this turns out and post a picture of your engine.
Regards.
Regards.
Thanks for the info. Since the diameter of the pin is 4mm exactly, this should work?
https://www.amazon.com/dp/B07SYYDTVZ/ref=ox_ya_os_product?th=1
