You see pewter as a metal for jewelry, cast figurines and utensils. Soft metal. Unlikely suitable for machining and drilling.
can you alloy pewter and alu?I'd love a supply of pewter. It's essentially tin(98%) and melts and casts accurately.
With a sufficiently good wall thickness, it can save hours of machining harder metals but the
cost is perhaps £50 retail after VAT and other taxes.
Its a bit like whisky which should be the same price as sausage i.e 6 Pence a skinful.
I'll drink to that
Happy Christmas
Thanks Dan but 'No'I still have a little stock if you require some Norman.
Dan.
I spent my very early career in a can plant and have a few comments . Yes, Tin Cans have been used for over 180 years. The "Side Seam " and the lids (called "ends")were hand soldered with 2/98 (Tin/Lead %) solder ( `612 F temp) and many times the insides had lumps of solder. Even when done by automation, the problem persisted. Food absorbed the lead and in the 1950-60's Japan led the battle to remove Lead from cans . . This led to the use of pure Tin solder in the 1970's by some can makers, but pure tin solder will crack after a period of time ( 2 yrs) and expose the contents to atmosphere ( spoilage). This led to the Welded 3 piece can ( 1 body & 2 ends) and that then became the 2 piece can where the steel body is drawn over a mandrel ( Technology learned from Aluminum beer cans ).............................................There is a theory that lead had an effect on the crews of the Franklin expedition in the Arctic. The tin can had just been invented and many were taken as stores on the ships. There was apparently high levels of lead in the solder used to make the cans. Examination of tins discarded in rubbish heaps on the shore showed great gouts of solder sticking into the inside of the cans. It is thought that food stored for a year in these tins would have been contaminated with lead from the solder and this contributed to the strange decisions that seemed to be made by the leaders of the expedition.
So what is alloyed with the tin these days to make pewter? Or is pewter effectively extinct?
Apparently that wasn't more of a problem for them than pretty much everyone in Britain, high levels of lead were found in just about everyone at the time. Lead Poisoning Wasn't a Major Factor in the Mysterious Demise of the Franklin ExpeditionThere is a theory that lead had an effect on the crews of the Franklin expedition in the Arctic.
