They both fun cut .OK. A36 is listed as structural steel, so I would expect it to be ugly to part-off. And DOM tubing has a welded seem. I haven't tried parting it, but I imagine the weld would provide an interruption to the cut, being harder than the rest of the tube. I can see that introducing chatter.
Something just trying different ways.Stiffness in the lathe is everything under heavy tool loads like parting-off. I have had various small lathes, fro a 1960s right-hand thread lathe with 3 in swing (my Grandfather's), and Unimat from 1960s to my current Chinese 6 in swing. None of these small tools work like big stiff lathes for parti -off. On a single piece of steel I have had 3 cuts consecutively where the part "worked Ok", next dug -in and next was best and fastest feed rate. The "worked Ok" cut was at a slower feed speed (by hand), because the workpiece was projecting more from the chuck, the next final was Ok when I figured a feed-rate that worked, and the last was close to the chuck.
I feel that the last time I sharpened my tungsten a carbide tool I must have got the grinding "just right" as it is set on a back tool post. My notion is that as the cuts were on different projections from the chuck that affected the total stiffness of the lathe and the bad cut was at a point where something was resonating at that stiffness. THe other cuts at different system stiffnesses didn't hit the resonance and therefore cut Ok.
Certainly, there is always a sweet-spot for feed rate , part rotational speed, etc. And the lathe bed stiffness is the thing you can't change. On smaller lathes I have seen the bed twist under dig-in loads, and this will happen on any lathe if you can get a high enough load. All the advice about tool rake, sharpness, finish, feed rate being higher, etc. is valuable as all these factors contribute to dig-in and chatter. But there are limits on every lathe and set-up where too high a feed will dig-in, and if you have any significant play you will get chatter. I suspect the initiator for resonance is the torque variation (quite a high frequency) from the poles of the motor, or belt drive resonance, or something relating to a ripple on the rotational speed. This excites resonant frequency or harmonic based on the stiffness of the whole lathe. Once initiated the resonance causes a ripple on to pressure which in turn causes momentary dig and release.... This then accelerates into chatter. CHANGE SOMETHING to change the stiffness and the chatter seems to magically dissapear. But what to change can be any of these various factors that make it work. It is a bit of a black at for the less experienced (I.E. me!).
Thanks for you advice - it has helped me.
Discuss.
Ken
Ken
I'm left guessing about your technique. Vaguely, I am left wondering what thickness is your carbide parting tool and secondly, what or how you are regrinding a carbide parting tool. I think that I shall not be alone in this.
Moi? I'm really a HSS guy but I DO have ability to /access to CBN and diamond stuff too.
Here, in the wilds of sometimes sunny Gosforth and in severe lockdown and shielding, I'm trying too keep a degree of sanity starting on Worden tool grinnder- theoretically to do hss stuff.
Norman
When I worked in the shop we had a number of brand new tool room lathes were snugged up the ways it seemed like daily finally the solution was to simply place a large chunk of steel plate on the carriages. I suppose you could say the machines wore out more but loss of production made this a moot point. I rented time at a horrid shop on his old mill. It chattered something terrible so I tightened the gibs as much as practical and set about 100 lbs chunk of steel on the table. Chatter gone. There was a mild confrontation but he was a business man too so we compromised budgets I said I’d clean the mess his helper made when I was done . Saved him half hour wage and it took me a few more minutes to finish the job that I made a couple hour engineering pay. ( very high rate for skilled toolmaker-with eng degree. Ya just gotta know how to bargain.LOLI have a mini-lathe with (as explained by someone else) the rigidity of a wet noodle but I can part off quite well with the sharp blade but I use a diamond honing stick as it needs to be sharper than what my grinder can do. Honing all my cutters is essential with this lathe.
I just saw the picture of the saw blade. In view of the riots here we were discussing over lunch defensive weapons. Even at my age being ex relief baseball pitcher I’d guess I could throw that thing through a 1/4” piece of plywood at 20 feet. Hate to be on the receiving side of that tool. Bedside gun is nice but very difficult to leave in very accessible position. I don’t sleep with leather gloves on but I could present that thing effectively.Mauro, thanks for reminding me to get MAIG and complete an idea from years back - to make a part off tool from a circular saw blade vis :-
I mostly use the 3/32" HSS blade and holder (top right) and was hoping this 2mm wide blade would be better.
For my first attempt, I was deliberately belligerent with the blade (stress test) without coolant - probably overheated and the tip came off.
Test #2 was done with care and coolant - it works but all in all is more trouble than my 2.4mm (3/32") blade.
So I'm going to call it a failure although the occasional job might still pop up where it might be useful.
Next I'm going to make a holder to take the standard 3/32" beveled blade and mount it at 5-7° so I don't have to grind the rake in the top and use the bevel as a chip narrowing device.
Regards, Ken
Sorry off topic but not off mind these days.I just saw the picture of the saw blade. In view of the riots here we were discussing over lunch defensive weapons. Even at my age being ex relief baseball pitcher I’d guess I could throw that thing through a 1/4” piece of plywood at 20 feet. Hate to be on the receiving side of that tool. Bedside gun is nice but very difficult to leave in very accessible position. I don’t sleep with leather gloves on but I could present that thing effectively.
