What causes it? I've made a very rigid parting tool holder that mounts directly on the compound and makes a very rigid setup. Usually works like a dream, but sometimes get chatter. It really seems to be a random event as it comes and goes with the same setup. Sometimes touching up the tool helps, but not always. The tool is spang on center and flat on top. I've tried varying the grind angle, sometimes it helps, usually does not. When it does smooth the cut, the next cut may chatter. Using a .090" wide blade. Chatter starts the moment the tool touches the part.
Using a WWII era HSS blade.
Any suggestions?
Bill
Any suggestions?
Bill
