Yes, I cut the threads on the worm myself.
It is a piece of 1/4 inch brass, 5/8" length, with a 1/8 shoulder on each end with a 40 thousands undercut at each end of the 1/4" long 1/4-20 thread. And a .032 wide slot cut into the side of the .125 hole through the piece to match up with the slot in the shaft so that a little key could be fit in between the gear and shaft. A rather complicated little part.
After my first attempt which turned out very sharp, I had to go to the real machine shop and ask what I was doing wrong the "MAN" looked at my cutter and decided that it was too pointy so he he showed me how to grind it properly with 20 degrees on each side with relief on both sides and a 12 thousandths flat on the tip.
Well, I came home tried again with a little cutting oil on it and taking cuts of about .005 on each pass but I didn't release the halfnut, I just ran the lathe in reverse back to the starting point went in another .005 and ran the lathe forward and did this until I reached the proper depth.
Finished up with a very tiny file on the bottom of the thread and it was "Good Enough For The Girls I Go With".
This is the first time that I have ever cut threads on the lathe, One more skill to had to my resume.
I'm off to the hobby shop tomorrow to try and find some paint. I am thinking either Black or a very dark Olive Green.
Stay Tuned...
Jack
