I've spent the last few days studying relationships!! No, not that kind of relationships, ya dirty buggers!! The relationship between engine speed, flywheel weight, and governor spring strengths. The heavier a flywheel is, then the greater a "kick" it needs to bring it up to a speed fast enough for the governors to come into play. That is why my engine had to fire five or six times in a row, each time giving another kick to the flywheel until it was spinning fast enough to trip the governors. At this time there were two ways I could have gone--#1-A lighter governor spring, or #2-a lighter flywheel. I chose to go with the lighter flywheel option, and after much dialing and tuning and disassembly/reassembly, I have it tuned to a point where my engine fires only two and sometimes 3 times before the flywheel is going fast enough for the governors to kick in. Also, I note that with the lighter flywheel, the engine runs at a faster speed than previously. I could shave some more weight off the flywheel, but then we get into the opposite side of the equation--The flywheel has to be heavy enough to carry the engine through 5 or 6 "miss" cycles, and still have enough inertia to compress a charge of fuel for firing after the governors disengage. I don't want to take more off my flywheel and have it too light. It is a lot easier to take metal off than it is to put it back on. Another option comes into play here, that I'm thinking about. The faster the flywheel is running, then the closer it is to the governor "trip point", and the less "kick" it needs to speed up to trip the governors.---However, that defeats the "I want my engine to run slowly" side of things. It's easier for me to change the governor spring than it is to remove and machine more off the flywheel, and at least with changing springs it is easier to "undo the change" than it is if too much weight is taken out of the flywheel.
