chucketn
Senior Citizen
I'm making an ER32 collet chuck for my 7x lathe. I have 2 pieces of stock. One is 1/2" steel from a scrap plate from a fixture or machine I got from a friend, the other is a piece of 2" steel barstock , also from a friend.I have cut out a circle from the plate with the bandsaw and mounted it on a 1/2" x 13 arbor and cleaned up bothe faces and the circumfrence. Same with the bar. I intend to bore the flat plate to fit the round, MIG weld them together, and turn and bore the chuck on the lathe.
My question is, should I set up the plate on the RT and drill and tap the attaching holes and turn the spindle registry before welding the two together?
I also plan to chamfer the flange plate on both sided of the hole to allow me to get a good weld.
Am I working in the right direction? Any suggestions?
Is welding better than sliver soldering/brazing?
Chuck
Edit: I'm following plans from http://mikesworkshop.weebly.com/er32-collet-chuck.html
Chuck
