Open thread on Edwards 5 Radial
Peter, we can consider our self lucky that modelenginenews.org website is still operational albeit limping. The user login validation does not work either.
Ron Chernich demise was a great loss to the model engine community.
The 4-stroke glow fuel is little different from the 2-stroke version. It might contain a little more oil and maybe a little less nitro, but that is about it. I wonder about the design philosophy behind the Edwards radial 5. With standard 4-stroke glow fuel widely available and the principle of lubing the crankcase with oil blow-by being a well proven technology, it seems to be an unnecessary complication to have a separate oil-lubed crankcase. It only makes sense if the fuel is oil free, hence my question.
My favorite fuel is Powermaster: https://vpracingfuels.com/rc-fuels/#aviation They list their fuel mix recipes on the web page. Most of them are listed as suitable for both 2 and 4-strokes.
The commercial multi-cylinder, glow-ignition 4-strokes like the OS Sirius, Pegasus, and Gemini use blow-by lubrication with great success. Good luck on your project.
WOB
The Edwards is a bit unique for typical glow in that it specifies methanol/nitro (only) as fuel, but has a pumped oil lubrication system. People that run it that way don't seem to have adverse issues from what I hear, including the designed ring system. Although some still opt to blend or dilute commercial 4S RC fuel into the mix for insurance. Most RC 4S glow engines use pre-blend fuel on a single compression ring, including radials but no auxiliary lubrication system. The Ohrdorf 5-cyl & 9-cyl radials use pre-mix but the nose case is oil filled for the planetary gears & cams to splash around. It is sealed from the crankcase internals.
I have yet to figure out how the upper cylinder rockers are lubricated (over and above maybe manual squirts). On many RC 4S engines the push rods are within O-ring sealed tubes & rockers under gasketed alve covers. I know the rockers are nice & oily from experience but not sure if its migrating up the pushrod or there is enough blow-by leakage from the valve stems & the tubes are intended to drain it somewhere?
    24.7 KB
Thank you Peter for shedding some light on the fuel issue.
Since buying nitromethane is nearly impossible I plan to dilute a commercial 10% nitro with equal parts methanol to halve the oil and the nitro down to the 5% recommended. It also seem that this approach allows the adjustment of nitro to the sweet spot.
On other engines I built it seems that the rockers need so little lubrication that one can wet them before a run and the effect last at least for a 10-15 minutes usual flight. Not planning to fly it though.
I have yet to figure out how the upper cylinder rockers are lubricated (over and above maybe manual squirts). On many RC 4S engines the push rods are within O-ring sealed tubes & rockers under gasketed alve covers. I know the rockers are nice & oily from experience but not sure if its migrating up the pushrod or there is enough blow-by leakage from the valve stems & the tubes are intended to drain it somewhere?[/QUOTE said:
The 4-stroke crankcase operates at a low positive pressure due to blow-by and a restrictive vent and I'm sure there is enough oil vapor present to go up the push rod tubes to the lower pressure area in the intake rocker boxes. Exhaust valve-stem blow-buy would likely lube the exhaust rocker box internals. This is a good reason to have a little looseness in valve-stem to valve-guide clearance. For engines with both rockers in the same box, it is likely both. Most hobbyist model 4-strokes are designed with open rocker arms and push rods. I never liked that feature and my 4-strokes have sealed rocker boxes and push rod tubes.
WOB
That finally explain to me how the Malcom Stride LYNX works. It has no push rods because is a OHC but it has a small pipe from crankcase to the cam case.
I omitted the oil pump and everything that goes with it because if all goes I want to fly it ( in the distant future).Like WOB says, almost all commercial 4-stroke model engines depend on crankcase lubrication by blow-by of oil-containing fuel.
I use only one piston ring and no oil scraper. With my limited machining capabilities I see no way to make a slot in a 1 mm wide piston ring. To provide adequate lubrication for the cam gear I separated the cam housing from the crankcase by omitting the holes and using sealed crankshaft bearings. I use outboard gearbox oil in the camhousing, so far I did not have any problems.
Rule of thumb sizing a carburetor is 10% of piston area.
Andrew in Melbourne
As a point of reference, the OS FR7-420, 7 cylinder radial ( 70CC) uses a # 80T carb. Don't know the throat size. Good price on Amazon.
WOB
Hi Edwards Radial enthusiasts.
I finished building my engine in 2015 and it has been running happily ever since on a Perry 2100 carb.
At the time I emailed Gary Conley at Perry carbs. and described the engine and this is the model he recommended for the application.
It has a throat dia. of .270". I just looked at their web page and this carby is still listed.
The build can be viewed at this HMEM link. http://www.homemodelenginemachinist.com/showthread.php?t=6923
Here is the link to the engine running on its second startup.
Cheers all and keep up the good work.
Radials Forever - Cheers from Brian in South Oz.
Thanks
Somewhere in the 0.250" matches my calculations.
Up to 4 cylinder the carb is sized based on single cylinder displacement.
Above 4 the intake air volume is increased by a factor N/4.
A 2 cylinders draws air pulses contiguous but not overlapping
A 4 cylinders draws air in a continuous/constant manner equal to the maximum speed of the single cylinder.
An 8 cylinders doubles the air stream of a 4
A 5 cylinders should run well on the same carburetor feeding a single of 1.25 times the radial single displacement.
Some latitude is allowed
A smaller throat may starve at high rev but keeps sufficient air velocity to nebulize the fuel at low rew
A larger throat may allow higher power at the expenses of a higher stable idle.
Since I do not plan to fly this engine at top power but like to see a low RPM idle I will lean toward the 0.226"
After loading the picture could not enter text.
Got it running today, started right up with no fuss.
I was concerned about the oil pump being such a fiddly design/construction but it work well. One can see the sump return flow speed away.
I tried to post a video but .MOV is not accepted.
I ran it first with a fly wheel because I dis not want to reach around a 20" prop to get to the carb. But after it started reliably I felt safe walking around. On to the next project: Lanz Tractor
