Old tractor Landini @scale 1/7
@ aerofourcycle. Yes, two time cast iron together and result is exceptional
Don't forget that my target is to have a slow rpm engine, and is will be better with "heavy" piston. But by the way, compression is very good with less leak between piston-piston ring and cylinder
@Demaic: ik heb geen vakmanschap en ben alleen amateur!
LeZap
The painting was made with binocular for better precision.
other pictures are détails of construction
LeZap
Hi Zapjack, Yes please continue wtih the photos and possibly a video,hope one day to scale those heights.
Cheers.
Allen.
Hello there, some other pictures
214-215 is the GO filter made from plexi and polished with tooth cream
217-218 general view of clutch command
219 air fan and piping
221 airbox butterfly screw 1.6mm
222 piping
223 light switch
LeZap
Thanks for this report, this is a high level of engineering!
Demaic
Sorry, I'm a little bit late in my post !!! apologies !!
pict 224 test mounting
226/227 electric wire piping. Diameter is 1.5mm (1/16")
228 Tank with battery - ignition - small tank
229 general view of lubrication and false pipes but real oil level!!!
230 gen. view of GO filter & piping
231 gen. view of chain transmission to air fan
232 test mounting
232a + 233 real tractor view
LeZap
Zapjack,
You've been busy adding more incredible detail to an already incredible model.
I like old tractors and both the model and the real one are impressive.
You may have said earlier, but do you own the real one, too?
Congratulations and Thank You for posting.
--ShopShoe
Hi Shopshoe, I've just started my 3rd tractor
This last one is a 4WD full metal wheels and articulated !!
So it's coming !!
LeZap
Hello Zapjack, I just found you build. Great build. Will follow any more builds that you may have. Looking forward to the next 4X4 tractor build.
