mklotz
There's no need for that cylinder on the circumference of the rotor.
Mount the rotor vertically on the surface plate and use a height gage to measure the distance from the circumference to a close-fitting gage pin inserted in the central bore.
You can do it by measuring the chord but then you have to know either the:
subtended angle
arc length
sagitta
to find the radius. The trig is easy but if it hurts your neurons you can use my program.
subtended angle
arc length
sagitta
