sbwhart said:Hi Robert
I found the best way to make the cylinders was to make the two together from one bit of bar then when you've got the bores done part them off but don't forget to mark them first so you connect them up in the same orientation they were drilled in, also take care to get them concentric with the bore and evenly spaced.
Good luck
Stew
Doing the bores as a one piece then separating really would reduce the error margin. At first I knew drilling a 2 inch deep hole using my tailstock wasn't going to work for me, its got alignment issues. Had forgotten that I made little holding plate for the carriage, when I ran across it the Ah Ha! thats what i need chime dinged.
Seen that Arnold, I believe, had to do a patch up after he separated the pieces, process looks sound. My reference point that I'm using to work around are the central pivot holes, know that the error increases as one moves out from that point so care is to be taken getting that index set. Wouldn't be the first time I shot myself in the foot
Have a little 3 inch RT if I need to, but am trying to build this thing with as few store bought toys as necessary. I've always bounced between "If its too hard make it easier and if its too easy make it harder"
Its the journey that's the adventure, once there its just another place. Bride thinks I'm nuts when I come in with the Old "Look what I made" grin, and for some reason is quick to leave the room as I begin to explain how.
Leaves just me and the remote, works every time
Robert
