spuddevans
- Feb 25, 2008
- 203
- 1
GailInNM said:Tim,
One thing to consider when making your ring light is the angle of illumination, sometimes specified as the viewing angle, of the LEDs. The LEDs you linked to do not specify what the angle is.
I suggest that you drill the holes in your plate at an angle so the LEDs point to a good average tool length distance for your setup. If you have a rotary table that you can tilt, or that you can mount at an angle, then it should be fairly easy. The angle you choose will be dependent on your own work setup.
I have thought that that would be the case, and I think that your solution with tilting the rotary table will work just great. I also would like to mount a couple of "straight line" laser's to the assembly as well to give a composite cross-hair indication of centre. Obviously the mounts for the lasers wll need to be adjustable.
Thanks for giving me a solution for drilling the led holes.
Tim
