I spent two evenings trying to come up with figures that matched Ed's. I failed miserably. I then got in touch with Ed who confirmed that his figures could also be wrong.
https://www.rcgroups.com/forums/showpost.php?p=36347313&postcount=12246
I am working up to larger sizes, now have a 7.5cc diesel which flies a 7foot span plane well.
Have now put the crankcase parameters into the drawing and initial thoughts on crankshaft design within the crankcase.
Note the inlet transfer ports have been slimmed down to 6mm from 8mm. I think 8mm would slow the gas speed too much. Have also shown the exhaust ring with either a slitting saw cutting the apeture, or you could use a slotting drill to make them if you don't have a slitting saw. I've shown a 20mm diameter saw, but any smaller diameter one will do, just go in so that the length of the slit is about the same.
In this drawing you will see the crankdisc with the crankpins 5mm long drawn at tdc and bdc. The disc is 5mm thick relieved a bit to create a land for the 10 x 19 x 5 deep ball bearing, a pretty common and not expensive size that will run to over 30,000rpm on the NTN catalogue.
Now as I am writing this I realise that there is a problem - the housing for the bearing is going to block a major portion of the forward inlet transfer port, so in the design of the housing it will have to be relieved here to create a free passage for the gases.
The crankdisc will be 21.1 diameter (14.6+4.5+2)and the shaft size at the ball bearing will be 10mm.
Having said all this - with this cylinder design you are not limited where you rotate the cylinder, to have the ports 90/180/270/360 degrees to the engine or maybe better still 45/135/225/315, that way no blanking of one of the inlet transfer ports. Although for aesthetics I would like them 90/180/270/360 - but you can always experiment by turning them once it is running of course. although once assembled and run in not a good idea o disturb the hard won piston/cylinder finish.
If you are still with me on this you can see there is a bit in just coming up with a simple design, sure wish I knew how to do CAD, as my penciling skills are pretty slow !
Yup, same for me for any other castings mate, emailed you already today.Ed-as per my reply on 'another' forum-put me down for one of each-the Buddy and the ED Baby (and should you be tempted to do another run of David Owen 'Mate' BB case castings-one of them as well..!
