alihureiby
Active Member
- Jan 15, 2013
- 36
- 13
Hi Ali,
If engine building is your cup of tea and you are looking for a small lathe because of the foot print or space , I would advise against these little toys.
Even if by a miracle the lathe happens to have some accuracy it is just too flimsy and small to do any usfull work. Sieg's own C1 ( I have this one ) would be a much better alternative and then you could either add the bolt on millng head ( X1 without the table) to the side of the mill at a later stage, buy a Sieg X1L and these will be a better choice.
Alternatively again if you are restricted by space , you could do worse than buying a Sherline or a Taig lathe, expensive in comparison but for a reason, these lathes are just in another league compared even to a C1 never mind this little toy. You will soon either out grow this lathe and wish you had a better, larger lathe or it will make you fed up with model engineering and give up all together because you will not be able to make anything precise enough or big enough.
Engine building of any sort particularly small scale IC ones require a great deal of skill and very precise instruments, I doubt very much if this lathe meets the requirement.
Hope that you didn't mind the advice.
A.G
yes you right, maybe the C2 is better ,
no question about taig and sherline, they are small but can do more like this
http://www.deansphotographica.com/machining/projects/projects.html
ali
