Yes thats trueThe drains look good, though they seem to have a very short length of the thread.
Hi jasonThe small blanked off one may well be to allow high pressure steam to the LP cylinder, sometimes used just for starting via a "simpling valve"
Can you see the hole from the inside of the LP chest?
Actually do you and charles got any smart ideeas for that piston valve?Hi jason
Its got a sleeve and that sleeve got the hohles inside around is a cavity
Bud if i blow smoke it comes out of the 1/2 inch hohle wich hot threads for a flange
Chris
Thank you charlesChris, out of interest, what is your first language?
If the arrangement is as I am thinking, then the copper pipe should connect to the central port in the low pressure slide valve face. Could you check that with a wire or smoke test? If we are right, then yes, it would go to the condenser.
The red diagram looks right.
If you get time charles could you haveThank you charles
Im originally from switzerland and emigrated to australia
Im from the german part in switzerland
So german and french at school
That and having italian mates also
Picking up italian swearing and …
I had to learn english here in sydney about
20 years ago
My wife is thay. We both not native english
Bud our 2 boys
They correcting us …. A lot
Thats why im metric
Bud im really completley sorry
I dont wanna piss anyone off
Chris
Thank you charlesOK. Let's go through the information we have for the design of the piston valve (from the various post numbers) and make sure we agree:
#140: valve rod diameter: Ø 5.9mm
#147: valve chamber bore: Ø 0.728" (18.49mm)
#231: dimensions of the porting holes. The critical ones are the two rows of six holes. These holes are 4.7mm diameter and are centred 46 mm apart (these dimensions are quite accurately 3/16" and 1-13/16")
#240: Jason's interpretation of the porting data
#256: Jason's measurements show the two HP eccentrics are about 110° apart (which means they have 35° advance (90-110/2), which is quite large)
#262: the eccentric throw is 1/4"
#283; the valve chamber bore is Ø 17.85mm (0.703") and the rod is Ø 5.95mm (15/64" almost exactly)
That is sufficient for me to get on with the valve design, and there is just one question: which is the correct bore for the piston valve 18.49mm or 17.85mm?
I got 1/4 32. ( for spark / glow plugs) M6. 0.8 or 1. 1/4 dieChris, what taps & dies do you have, around 6mm or 1/4" and a little larger?
The hohle in the cast is a bit bigger than the brass sleeve thats why the 2 measurmentsOk charles im back
The bore is 17.88mm
The sleeve inside is brass or bronze
About the tab and dies
Just specify the thread i can order it
On the rod end is no thread
