More picsSorry I didnt got it 3x
Anyway
I shot better pics from the inside before i start so u can see again
If ok i start measure
see in the small one are hohles
The big triangle is round inside
Tegards chris
Anyway
Tegards chris
Hi jason it iscan you take a piece of wire and see if the openings at the ends of the round HP valve chest (1) are linked to the ones at the ends of the LP chest. (2)
If they are linked then that is how the exhaust steam from the HP cylinder gets to the LP chest via cored in passages around the side of the LP chest. It's a bit of a long route but would have acted as a bit of a reciever.
l also forgot to show this lever properlyHi jason it is
Im happy to measure it
As green twin mentioned with the d valve
Bud there must be soemthing else in the small hohle
I dont think alan got more parts
He used it as doorstopper…
Welll
Regards chris
Ok thank you jasonMost of those shots with the wire are as I would have expected. It is what links the round piston valve chamber to the slide valve chamber that would be good to know. You might have to poke it in from either end and just get an idea of where it is going as the wire may not bend all the way round. Then measurements can be taken to sort out what needs to be made.
Start tomorrow with the wire and send picOk thank you jason
I will do that
