Gus---There is a trick you should be aware of when you go to machine the valves. I have posted about this before, but I can't remember where now. If you try and turn down the full length of valve in successive passes, once the diameter is reduced close to where you want it, the material will start to deflect away from the cutter, causing major headaches----This is assuming you are holding the work in a 3 jaw chuck without a tailstock center. The trick is to turn only about 1/4" of length down close to the desired diameter, maybe .001 to .002 larger than finished diameter. Take note of the numbers on your crossfeed dial, then back out and turn the next 1/4" of material down. Keep doing this until you have the valve stem to the correct length, then polish to size with fine emery paper. By doing it this way, you can avoid the deflection which is sure to happen otherwise and cause you grief. I think it was George Britnell who gave me this advise when I built my first i.c. engine. Make sure that you have the part that the valve stem fits into machined and finish reamed to size before you make the valves--That way you can keep trying for fit without "unchucking" your valve and lose concentricity with your chuck.----Brian.
I have used these hone they give a brilliant finish
http://www.brushresearch.com/product-line.php?line=1
Good Luck
Errol
Following along Gus, progress so far looks great. Don't let cutting the gear worry you, approach it with a positive attitude and you will have no trouble.
Paul.
Looking good Gus. Damn, that's a big sparkplug you've got in that thing.-Is it out of a car?
And further advice I got from George Britnell is that it is only the part of the valve stem that slides in the guide that needs to be spot on for size.
Jim
