I was surfing YouTube recently and stumbled across some videos by an Australian company called Rotec. This is a relatively small company that builds and sells full-size radial engines to homebuilt aircraft enthusiasts. I had previously been only vaguely familiar with Rotec, having seen a video of one of their engines running in a custom-buit motorcycle. The video that I stumbled across was probably made early in the company's history. It's a video of a quarter scale nine cylinder engine that, if you don't look carefully, you will swear is another Hodgson model with the optional rocker boxes.
[ame]https://m.youtube.com/watch?v=bP3-WSvnGIY[/ame]
The heads are essentially identical to stock Hodgsons with the main visual difference between the engines being the location of the distributor which, in the Rotec design, is on the crankshaft axis. The video of the 350 (cc) is evidently an early run of the small scale prototype built to test their design before starting the full scale build. If you listen carefully at the end of this video you'll hear someone in their group watching the test say "OK, but it will never work in a real plane."
There are several other videos including this one showing some highlights of their manufacturing process:
[ame]https://m.youtube.com/watch?v=CVu6vjPvxkg[/ame]
that was probably made sometime later. Those who have built a Hodgson-9 will see some steps eerily similar to those performed during their own builds. You'll also notice the familiar intake/exhaust flange milled into the rear of the heads. A change in the head design to note, though, is a modification they made to support two spark plugs per head. As it turns out, the full-size Rotec design includes redundant ignition systems - spark and magneto.
This video will bring a smile to the faces of all who have actually built a Hodgson or similar model radial:
[ame]https://m.youtube.com/watch?v=jwpnucBidGQ[/ame]
where the technician, who looks a lot like the guy in the 350 video, is explaining how to troubleshoot failures in the spark ignition system. If you watch carefully you'll see him holding a familiar red, white, and black three wire cable while explaining how to ohmmeter test the Hall sensor inside the distributor. - Terry
