Finally tonight I managed to get back into the workshop.
I was away for 1 1/2 weeks for work and then once I got back I had a stack of other jobs to do before I could get back into the workshop.
The first thing I needed to do was burnish the teeth on the ratchet.
I didn't own a burnisher small enough and yes I could of got some 1/16 silver steel hardened and tempered it and then polished it up but I took the easy approach.
On the way home dropped by Spotlight which is a shop in Australia that sells all the stuff you need for sewing, knitting etc and got myself a medium size wool needle (the wool needle was chosen as it doesn't have a sharp point.
A quick trip to the grinder to take off the eye of the needle and I had a perfectly sized hardened and polished burnisher which I held in my pin vice.
After burnishing the holes for the 8BA roundhead screws were marked out, drilled, counter drilled and tapped.
Here it is in the lathe to trim the screws to size and put an undercut to strop friction when the ratchet turns against the main wheel when resetting the weight.
All finished.
Its not perfect but it is good enough for what is really a learning project.
One part finished, many to go.
