I made the piston and piston rod assembly to day. I used steel for the piston and
1/16th music wire and silver soldered them. My first ever silver solder job. ;D I made 2 assemblies just in case. One assembly I had to do over. But it is good now.
I used white vinegar as a pickle and it worked great. I left the parts in for approx 45 min. and the wiped off very clean.
I used a standard Bernzamatic propane torch ait worked well to on the 1/4 in. piston and 1/16 in wire.
I did learn a lot about small hole drilling, went thru five 1/16th drill bits before I learned though. :wall: :wall:
Ron
