TheHomeMechanic
- Jun 13, 2018
- 12
- 1
Hello everyone,
recently i got my lathe working and i decided to work on a small nitro engine project.
This is the first i ever make, so let's hope it works out
I had 2 pieces of stock of 42mm and a few of 28mm.
I reduced the diameter to 40mm for the cylinder OD.
Then i made a sleeve to fit inside the cylinder, wich ended up being 16mm.
(I know, it's an aluminium sleeve, should be iron or steel. But it just needs to run a bit, not a long time.)
Then i pressed the 2 together and bored out the sleeve to exactly 16.00mm.
After that i decided to make a small piston. 20mm long (which would make it a 14,5mm stroke) and 15,96mm thickness.
Then i decided to make the most simple head possible (it needs some more work later).
And i thread an m8 thread in it for the glowplug.
and this is soemwhat of the current finished product. I still need to cut the chamber and put holes through it for the head bolts.
This is how i was planning to bore the holes (m4's).
Printing out the plans and glue them on.
This is how far i am currently, i will post updates later. Any tips welcome
