raveney
Hello All,
Last weekend I machined the sand casted flywheels. There was a fair bit of filing required to clean up the spokes, but the rest of the machining was straight up lathe work using a faceplate to bore the shaft, taper the hub, and cleanup a few spots where the pattern didn't pull cleanly on the inner rim.
Then I fastened each one to an 7/16" arbor and trued up the outer diameter. I had to use the boring bar upside down and run the lathe in reverse to get this to work on my 7X14 mini-lathe but got a very good finish using auto feed at 500 RPM with copious spraying of WD-40. The aluminum that was remelted to cast these is giving a very nice surface finish so far, unlike other extruded melts that I have done which were gummy and smeared.
Then I broached the keyways, primed the centers and set aside to dry. I will polish up right before final assembly as the aluminum seems to scratch easily unlike cast iron.
