Maryak said:CC and Dave
Try it sometime.![]()
Best Regards
Isn't it exciting ??? ??? ::
At the end of day one I looked in my starting corner and observed that the whole damn thing had moved because some of the wedges had slipped under the plasterboard.
kvom said:I used wedges on the first hardwood floor I laid, and had the same problem. Turns out I could slide the assembled floor enough to get it straight again. Then I put a bunch of heavy weights on the starting row to anchor it down.
In my case I put the baseboards on after the floor was laid.
steamer said:Looking good Bob!....laying floor is tough work....it just looks easy ;D
cobra428 said:Bob,
So when I'm I coming over for Shrimps on the Barbie and some Fost's
Tony
cfellows said:When it comes to building or improving your home, nothing is ever as easy as you think it's going to be. I'm running in to this every day in the 4-year-old house we just moved into. But you are continuing to move forward and the results look great!
sparky961 said:I'll second this. I just moved a bunch of the heavy cartons of flooring onto the few rows of newly-laid flooring to keep it in place.
Stan said:Like many on this side of the world, I am really interested in your house build so I have more questions.
If the foam is 3mm then I am guessing that this is a floating floor. Is the 'hardwood' a solid wood or a composite and how thick is it? Is this a material that interlocks on the edges and ends?
